Fujifilm FinePix S1 LCD Screen Replacement
  1. Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Remove the 4 screws surrounding the LCD screen.
  2. Fujifilm FinePix S1 LCD Screen Replacement: step 2, image 1 of 1
    • Use an opening tool to remove the casing on the hinge of the LCD screen.
  3. Fujifilm FinePix S1 LCD Screen Replacement: step 3, image 1 of 2 Fujifilm FinePix S1 LCD Screen Replacement: step 3, image 2 of 2
    • Use an opening tool to pry apart the LCD screen casing and remove the casing.
  4. Fujifilm FinePix S1 LCD Screen Replacement: step 4, image 1 of 1
    • Remove the 2 screws located on the inner corners of the inside of the LCD screen.
  5. Fujifilm FinePix S1 LCD Screen Replacement: step 5, image 1 of 2 Fujifilm FinePix S1 LCD Screen Replacement: step 5, image 2 of 2
    • Disconnect the blue cable set by carefully prying it off with a spudger.
  6. Fujifilm FinePix S1 LCD Screen Replacement: step 6, image 1 of 2 Fujifilm FinePix S1 LCD Screen Replacement: step 6, image 2 of 2
    • Use a spudger to lift the LCD screen out of its placement and remove it from the casing.
Brandon Benavente
677 Reputation
6 Guides authored
USF Tampa, Team 3-6, Sullivan Spring 2016 Member of USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 838
