Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: step 1, image 1 of 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: step 2, image 1 of 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: step 3, image 1 of 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
Insert your new batteries, close the battery chamber, and you're done!
Greg Sweeney
137 Reputation
1 Guide authored
USF Tampa, Team 7-1, Remmell Winter 2015 Member of USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 Members
9 Guides authored
3 Comments
should there be an indicator led to show the camera is charing ?
tony smith - Reply
should the camera indicate that it is being charged ?
tony smith - Reply
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 21
All Time: 1,753
