Fujifilm FinePix S8630 Flashbulb Replacement
  1. Fujifilm FinePix S8630 Flashbulb Replacement, Battery Door: step 1, image 1 of 1
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Flashbulb Replacement: step 2, image 1 of 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Flashbulb Replacement: step 3, image 1 of 1
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Flashbulb Replacement: step 4, image 1 of 2 Fujifilm FinePix S8630 Flashbulb Replacement: step 4, image 2 of 2
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Flashbulb Replacement: step 5, image 1 of 1
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Flashbulb Replacement: step 6, image 1 of 3 Fujifilm FinePix S8630 Flashbulb Replacement: step 6, image 2 of 3 Fujifilm FinePix S8630 Flashbulb Replacement: step 6, image 3 of 3
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Flashbulb Replacement: step 7, image 1 of 3 Fujifilm FinePix S8630 Flashbulb Replacement: step 7, image 2 of 3 Fujifilm FinePix S8630 Flashbulb Replacement: step 7, image 3 of 3
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Flashbulb Replacement, LCD Screen: step 8, image 1 of 3 Fujifilm FinePix S8630 Flashbulb Replacement, LCD Screen: step 8, image 2 of 3 Fujifilm FinePix S8630 Flashbulb Replacement, LCD Screen: step 8, image 3 of 3
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Flashbulb Replacement, Flashbulb: step 9, image 1 of 3 Fujifilm FinePix S8630 Flashbulb Replacement, Flashbulb: step 9, image 2 of 3 Fujifilm FinePix S8630 Flashbulb Replacement, Flashbulb: step 9, image 3 of 3
  10. Fujifilm FinePix S8630 Flashbulb Replacement: step 10, image 1 of 3 Fujifilm FinePix S8630 Flashbulb Replacement: step 10, image 2 of 3 Fujifilm FinePix S8630 Flashbulb Replacement: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Using the tweezers remove the flashbulb.
Colton Lancsarics
731 Reputation
6 Guides authored
USF Tampa, Team 3-2, Sullivan Spring 2016 Member of USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Members
12 Guides authored
One Comment
How do you discharge the capacitor on this model?
Flipping Turtle - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 382
