Fujifilm FinePix T500 LCD Screen Replacement
George Lindner
George Lindner and 6 other contributors
Last updated on February 16, 2025
15 - 20 minutes
Easy
Introduction
Go to step 1
The LCD screen on the Fujifilm FinePix T500 is a crucial component that facilitates viewing images, configuring settings, and selecting various modes. This guide is designed to assist you in replacing the LCD screen, allowing you to extend the life of your camera without having to purchase a new one.
Tools
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Fujifilm FinePix T500 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 LCD Screen Replacement: step 2, image 1 of 3 Fujifilm FinePix T500 LCD Screen Replacement: step 2, image 2 of 3 Fujifilm FinePix T500 LCD Screen Replacement: step 2, image 3 of 3
    • Open the battery compartment and remove the battery.
    • Carefully pry the front half of the casing away from the camera.
    • Pay close attention to the sensor cover—a small piece of translucent plastic—as it may fall out of place. If it does, place it back in its original position.
  3. Fujifilm FinePix T500 LCD Screen Replacement: step 3, image 1 of 2 Fujifilm FinePix T500 LCD Screen Replacement: step 3, image 2 of 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 LCD Screen Replacement: step 4, image 1 of 3 Fujifilm FinePix T500 LCD Screen Replacement: step 4, image 2 of 3 Fujifilm FinePix T500 LCD Screen Replacement: step 4, image 3 of 3
    • Lift the LCD screen out of the camera.
    • Locate the tab securing the ribbon cable that connects the screen to the motherboard. Using a spudger, gently lift the tab to release the ribbon. Carefully disconnect the screen from the motherboard.
George Lindner
252 Reputation
2 Guides authored
USF Tampa, Team 19-3, Blackwell Winter 2015 Member of USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 685
