Fujifilm FinePix T500 Lens Replacement
  1. Fujifilm FinePix T500 Lens Replacement, LCD Screen: step 1, image 1 of 3 Fujifilm FinePix T500 Lens Replacement, LCD Screen: step 1, image 2 of 3 Fujifilm FinePix T500 Lens Replacement, LCD Screen: step 1, image 3 of 3
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Lens Replacement: step 2, image 1 of 3 Fujifilm FinePix T500 Lens Replacement: step 2, image 2 of 3 Fujifilm FinePix T500 Lens Replacement: step 2, image 3 of 3
    • Open the battery chamber and remove the battery.
    • Pry the front half of the casing from the camera.
    • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  3. Fujifilm FinePix T500 Lens Replacement: step 3, image 1 of 2 Fujifilm FinePix T500 Lens Replacement: step 3, image 2 of 2
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Lens Replacement: step 4, image 1 of 3 Fujifilm FinePix T500 Lens Replacement: step 4, image 2 of 3 Fujifilm FinePix T500 Lens Replacement: step 4, image 3 of 3
    • Lift the LCD screen out of the camera.
    • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Lens Replacement, Lens: step 5, image 1 of 1
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Lens Replacement: step 6, image 1 of 3 Fujifilm FinePix T500 Lens Replacement: step 6, image 2 of 3 Fujifilm FinePix T500 Lens Replacement: step 6, image 3 of 3
    • Pry the center casing off the camera. This is best done by separating the top and side sections individually.
  7. Fujifilm FinePix T500 Lens Replacement: step 7, image 1 of 3 Fujifilm FinePix T500 Lens Replacement: step 7, image 2 of 3 Fujifilm FinePix T500 Lens Replacement: step 7, image 3 of 3
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Lens Replacement: step 8, image 1 of 2 Fujifilm FinePix T500 Lens Replacement: step 8, image 2 of 2
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Lens Replacement: step 9, image 1 of 3 Fujifilm FinePix T500 Lens Replacement: step 9, image 2 of 3 Fujifilm FinePix T500 Lens Replacement: step 9, image 3 of 3
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Lens Replacement: step 10, image 1 of 2 Fujifilm FinePix T500 Lens Replacement: step 10, image 2 of 2
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
Brian Lasher
313 Reputation
3 Guides authored
USF Tampa, Team 19-3, Blackwell Winter 2015 Member of USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,093
