Fujifilm FinePix XP50 LCD Screen Replacement
  1. Fujifilm FinePix XP50 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP50 LCD Screen Replacement: step 2, image 1 of 2 Fujifilm FinePix XP50 LCD Screen Replacement: step 2, image 2 of 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP50 LCD Screen Replacement: step 3, image 1 of 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP50 LCD Screen Replacement, Button: step 4, image 1 of 2 Fujifilm FinePix XP50 LCD Screen Replacement, Button: step 4, image 2 of 2
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP50 LCD Screen Replacement: step 5, image 1 of 1
    • Pull the three buttons out.
  6. Fujifilm FinePix XP50 LCD Screen Replacement, Front and Back Panel: step 6, image 1 of 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP50 LCD Screen Replacement: step 7, image 1 of 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP50 LCD Screen Replacement: step 8, image 1 of 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP50 LCD Screen Replacement: step 9, image 1 of 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP50 LCD Screen Replacement: step 10, image 1 of 2 Fujifilm FinePix XP50 LCD Screen Replacement: step 10, image 2 of 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP50 LCD Screen Replacement: step 11, image 1 of 1
    • Lift off the front plate.
  12. Fujifilm FinePix XP50 LCD Screen Replacement: step 12, image 1 of 3 Fujifilm FinePix XP50 LCD Screen Replacement: step 12, image 2 of 3 Fujifilm FinePix XP50 LCD Screen Replacement: step 12, image 3 of 3
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP50 LCD Screen Replacement, Back Panel: step 13, image 1 of 1
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP50 LCD Screen Replacement: step 14, image 1 of 3 Fujifilm FinePix XP50 LCD Screen Replacement: step 14, image 2 of 3 Fujifilm FinePix XP50 LCD Screen Replacement: step 14, image 3 of 3
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP50 LCD Screen Replacement: step 15, image 1 of 1
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP50 LCD Screen Replacement: step 16, image 1 of 2 Fujifilm FinePix XP50 LCD Screen Replacement: step 16, image 2 of 2
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
  17. Fujifilm FinePix XP50 LCD Screen Replacement, LCD Screen: step 17, image 1 of 1
    • Use the plastic opening tool to gently lift the LCD screen up.
Cory Teixeira
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 406
