Fujifilm FinePix XP70 Front and Back Panel Replacement
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: step 1, image 1 of 1
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 2, image 1 of 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: step 2, image 2 of 2
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 3, image 1 of 1
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: step 4, image 1 of 1
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 5, image 1 of 1
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 6, image 1 of 1
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 7, image 1 of 1
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 8, image 1 of 2 Fujifilm FinePix XP70 Front and Back Panel Replacement: step 8, image 2 of 2
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 9, image 1 of 1
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: step 10, image 1 of 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: step 10, image 2 of 3 Fujifilm FinePix XP70 Front and Back Panel Replacement: step 10, image 3 of 3
    • Pry the back plate off with a plastic opening tool
Olivia A
484 Reputation
4 Guides authored
One Comment
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 408
