Fujifilm FinePix XP80 Lens Replacement
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: step 1, image 1 of 3 Fujifilm FinePix XP80 Lens Replacement, Battery: step 1, image 2 of 3 Fujifilm FinePix XP80 Lens Replacement, Battery: step 1, image 3 of 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: step 2, image 1 of 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: step 3, image 1 of 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: step 4, image 1 of 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: step 5, image 1 of 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: step 6, image 1 of 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: step 7, image 1 of 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: step 8, image 1 of 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: step 9, image 1 of 2 Fujifilm FinePix XP80 Lens Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: step 10, image 1 of 1
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: step 11, image 1 of 1
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: step 12, image 1 of 1
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: step 13, image 1 of 3 Fujifilm FinePix XP80 Lens Replacement: step 13, image 2 of 3 Fujifilm FinePix XP80 Lens Replacement: step 13, image 3 of 3
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: step 14, image 1 of 1
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: step 15, image 1 of 1
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
Amanda Lewis
317 Reputation
3 Guides authored
USF Tampa, Team 1-3, Cagle Fall 2016 Member of USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,535
