Fujifilm FinePix Z1 Battery Access Door Spring Replacement
  1. Fujifilm FinePix Z1 Battery Access Door Spring Replacement, Battery Access Door Spring: step 1, image 1 of 1
    • Locate the Battery Access Door on the bottom of the camera.
    • Ensure that the door has no obvious cracks or damage.
    • See if the door slides out and opens completely.
  2. Fujifilm FinePix Z1 Battery Access Door Spring Replacement: step 2, image 1 of 3 Fujifilm FinePix Z1 Battery Access Door Spring Replacement: step 2, image 2 of 3 Fujifilm FinePix Z1 Battery Access Door Spring Replacement: step 2, image 3 of 3
    • Apply pressure to the door and pop the component out.
    • Using a H0.7 bit, push the rod out of the door to remove it from the camera.
    • Adjust or replace the spring.
Carra
533 Reputation
4 Guides authored
Baylor, Team S2-G4, Johnson Spring 2018 Member of Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 12
All Time: 202
