Fujifilm FinePix Z5 LCD Screen Replacement
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: step 2, image 1 of 2 Fujifilm FinePix Z5 LCD Screen Replacement: step 2, image 2 of 2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: step 3, image 1 of 3 Fujifilm FinePix Z5 LCD Screen Replacement: step 3, image 2 of 3 Fujifilm FinePix Z5 LCD Screen Replacement: step 3, image 3 of 3
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: step 4, image 1 of 2 Fujifilm FinePix Z5 LCD Screen Replacement: step 4, image 2 of 2
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: step 5, image 1 of 2 Fujifilm FinePix Z5 LCD Screen Replacement: step 5, image 2 of 2
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: step 6, image 1 of 1
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
Kyle Kaczmar
14 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 990
