Fujifilm FinePix Z5 Motherboard Replacement
  1. Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Fujifilm FinePix Z5 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Motherboard Replacement: step 2, image 1 of 2 Fujifilm FinePix Z5 Motherboard Replacement: step 2, image 2 of 2
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Motherboard Replacement: step 3, image 1 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 3, image 2 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 3, image 3 of 3
    • Remove the back of the camera by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Motherboard Replacement: step 4, image 1 of 2 Fujifilm FinePix Z5 Motherboard Replacement: step 4, image 2 of 2
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Motherboard Replacement: step 5, image 1 of 2 Fujifilm FinePix Z5 Motherboard Replacement: step 5, image 2 of 2
    • Using a plastic opening tool, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Motherboard Replacement: step 6, image 1 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 6, image 2 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 6, image 3 of 3
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold ribbon cable which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw on the right side which is anchoring the motherboard.
  7. Fujifilm FinePix Z5 Motherboard Replacement: step 7, image 1 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 7, image 2 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 7, image 3 of 3
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Motherboard Replacement: step 8, image 1 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 8, image 2 of 3 Fujifilm FinePix Z5 Motherboard Replacement: step 8, image 3 of 3
    • Hold wires on the left with an index finger.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
Lauren Gibbs
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 683
