Introduction
The best way to solve the problem is to replace the battery or check if it is facing in the right direction.
Open the battery cover that is located on the bottom of the camera on the right side by pushing firmly and sliding it forward. The cover should lift open.
Press the yellow lever to release the battery. Pull the battery out of the camera.
Insert the new battery and close the battery cover.
Almost done!
