Fujifilm Finepix F10 6.3 MP LCD Replacement
  1. Fujifilm Finepix F10 6.3 MP LCD Replacement, Back Cover: step 1, image 1 of 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP LCD Replacement: step 2, image 1 of 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP LCD Replacement: step 3, image 1 of 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP LCD Replacement: step 4, image 1 of 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: step 4, image 2 of 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: step 4, image 3 of 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP LCD Replacement, LCD: step 5, image 1 of 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP LCD Replacement: step 6, image 1 of 1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP LCD Replacement: step 7, image 1 of 2 Fujifilm Finepix F10 6.3 MP LCD Replacement: step 7, image 2 of 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Sarah Looper
100 Reputation
7 Guides authored
Clemson, Team 13-4, Benson Spring 2013 Member of Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Members
16 Guides authored
3 Comments
Great Guide! Worked great to replace my screen!
Daniel - Reply
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Reply
Shutter button replacement was great too!
Daniel -
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 20
All Time: 1,014
