Fujifilm Finepix F10 6.3 MP Lens Replacement
  1. Fujifilm Finepix F10 6.3 MP Lens Replacement, Back Cover: step 1, image 1 of 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Replacement: step 2, image 1 of 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Replacement: step 3, image 1 of 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Replacement: step 4, image 1 of 3 Fujifilm Finepix F10 6.3 MP Lens Replacement: step 4, image 2 of 3 Fujifilm Finepix F10 6.3 MP Lens Replacement: step 4, image 3 of 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Replacement, Front cover: step 5, image 1 of 1
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Lens Replacement: step 6, image 1 of 1
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Lens Replacement: step 7, image 1 of 2 Fujifilm Finepix F10 6.3 MP Lens Replacement: step 7, image 2 of 2
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: step 8, image 1 of 3 Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: step 8, image 2 of 3 Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: step 8, image 3 of 3
    • Firmly grasp the lens and pull completely from housing.
2 other people completed this guide.
Sarah Looper
100 Reputation
7 Guides authored
Clemson, Team 13-4, Benson Spring 2013 Member of Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 32
All Time: 1,786
