Fujifilm Finepix S1000fd Display Screen Replacement
Lizzie Eller
Lizzie Eller and 4 other contributors
Last updated on April 18, 2020
10 minutes
Moderate
Introduction
Go to step 1
Use caution when going through with the procedure. This procedure involves doing operations near the motherboard of the device, which has many sensitive components.
Tools
Show more…
  1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: step 1, image 1 of 2 Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: step 1, image 2 of 2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Display Screen Replacement: step 2, image 1 of 2 Fujifilm Finepix S1000fd Display Screen Replacement: step 2, image 2 of 2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Display Screen Replacement: step 3, image 1 of 1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Display Screen Replacement, Display Screen: step 4, image 1 of 1
    • Use a plastic opening tool to lift up the right side of the display screen.
  5. Fujifilm Finepix S1000fd Display Screen Replacement: step 5, image 1 of 1
    • Once the screen is out, you will realize that it is still connected to the ribbon cable. To unplug this ribbon cable, use a plastic opening tool to pull up and to the left on the ribbon cable connector and release the ribbon cable.
  6. Fujifilm Finepix S1000fd Display Screen Replacement: step 6, image 1 of 1
    • Using your PH00 screwdriver, unscrew the 0.5mm screw located on the bottom left hand corner where the display screen used to be.
  7. Fujifilm Finepix S1000fd Display Screen Replacement: step 7, image 1 of 1
    • Use the PH00 screwdriver to unscrew the 0.5mm screws located near the top left corner, top right corner, and bottom right corner.
  8. Fujifilm Finepix S1000fd Display Screen Replacement: step 8, image 1 of 1
    • Lift up the gray component where the display screen use to sit in.
Lizzie Eller
422 Reputation
4 Guides authored
Cal Poly, Team 8-7, Banghart Winter 2017 Member of Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Members
10 Guides authored
One Comment
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 25
All Time: 1,018
