Fujifilm Finepix S1000fd Leather Grip Replacement
  1. Fujifilm Finepix S1000fd Leather Grip Replacement, Rear Cover Casing: step 1, image 1 of 2 Fujifilm Finepix S1000fd Leather Grip Replacement, Rear Cover Casing: step 1, image 2 of 2
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Leather Grip Replacement: step 2, image 1 of 2 Fujifilm Finepix S1000fd Leather Grip Replacement: step 2, image 2 of 2
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Leather Grip Replacement: step 3, image 1 of 1
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Leather Grip Replacement, Leather Grip: step 4, image 1 of 1
    • Using the metal spudger, place it in between the leather grip and the black plastic compartment
  5. Fujifilm Finepix S1000fd Leather Grip Replacement: step 5, image 1 of 1
    • Repeat Step 4 for the other side
    • Remove the leather grip
Lizzie Eller
422 Reputation
4 Guides authored
Cal Poly, Team 8-7, Banghart Winter 2017 Member of Cal Poly, Team 8-7, Banghart Winter 2017
CPSU-BANGHART-W17S8G7
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 479
