Fujifilm Finepix S1800 Back Cover Assembly Replacement
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: step 1, image 1 of 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: step 2, image 1 of 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: step 3, image 1 of 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: step 4, image 1 of 2 Fujifilm Finepix S1800 Back Cover Assembly Replacement: step 4, image 2 of 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
Ryan Rockford
618 Reputation
5 Guides authored
USF Tampa, Team 8-6, Eyestone Spring 2017 Member of USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 400
