Fujifilm Instax Mini 70 Shell Replacement
  1. Fujifilm Instax Mini 70 Shell Replacement, Shell: step 1, image 1 of 2 Fujifilm Instax Mini 70 Shell Replacement, Shell: step 1, image 2 of 2
    • Look at the bottom of the camera and find the four 6 mm Phillips #0 screws and remove them.
  2. Fujifilm Instax Mini 70 Shell Replacement: step 2, image 1 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 2, image 2 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 2, image 3 of 3
    • Use a jimmy to separate the front and back shells. Then, use your hands to gently pull the back shell away from the front until it fully detaches.
  3. Fujifilm Instax Mini 70 Shell Replacement: step 3, image 1 of 2 Fujifilm Instax Mini 70 Shell Replacement: step 3, image 2 of 2
    • At the top of the camera, locate the 8 mm Phillips #0 screw and remove it.
  4. Fujifilm Instax Mini 70 Shell Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 70 Shell Replacement: step 4, image 3 of 3
    • Use your hands to gently pull the front shell off of the camera.
Jaime Arriaga
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 20
All Time: 169
