Fujifilm Instax Mini 8 Capacitor Replacement
  1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: step 1, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: step 1, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: step 1, image 3 of 3
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Capacitor Replacement: step 2, image 1 of 2 Fujifilm Instax Mini 8 Capacitor Replacement: step 2, image 2 of 2
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Capacitor Replacement: step 3, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 3, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 3, image 3 of 3
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Capacitor Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 4, image 3 of 3
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Capacitor Replacement: step 5, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 5, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 5, image 3 of 3
    • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
  6. Fujifilm Instax Mini 8 Capacitor Replacement: step 6, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 6, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 6, image 3 of 3
    • Carefully pry out the capacitor with a spudger or plastic opening tools.
  7. Fujifilm Instax Mini 8 Capacitor Replacement: step 7, image 1 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 7, image 2 of 3 Fujifilm Instax Mini 8 Capacitor Replacement: step 7, image 3 of 3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
4 other people completed this guide.
Boyang Wu
955 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
25 Guides authored
2 Comments
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - Reply
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - Reply
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 177
All Time: 24,985
