Fujifilm Instax Mini 8 Flash Unit Replacement
  1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: step 1, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: step 1, image 2 of 2
    • You start off with the camera.
  2. Fujifilm Instax Mini 8 Flash Unit Replacement: step 2, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement: step 2, image 2 of 2
    • Open up the back and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Flash Unit Replacement: step 3, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement: step 3, image 2 of 2
    • Remove the two Phillips #00 screws from the bottom of the camera.
    • Remove the two screws on the side of the camera.
    • Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Flash Unit Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 4, image 3 of 3
    • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
    • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
  5. Fujifilm Instax Mini 8 Flash Unit Replacement: step 5, image 1 of 1
    • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
  6. Fujifilm Instax Mini 8 Flash Unit Replacement: step 6, image 1 of 2 Fujifilm Instax Mini 8 Flash Unit Replacement: step 6, image 2 of 2
    • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
  7. Fujifilm Instax Mini 8 Flash Unit Replacement: step 7, image 1 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 7, image 2 of 3 Fujifilm Instax Mini 8 Flash Unit Replacement: step 7, image 3 of 3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
5 other people completed this guide.
Bo W
1,037 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
26 Guides authored
10 Guide Comments
Where can I purchase the flash unit?
Casey Sanders - Reply Share
Hi, did you ever find out where to replace the flash light unit?
Rachel Street - Share
Why is all the camera lights flashing red and doesn't work?
medgabby - Reply Share
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - Reply Share
Where can I find the flash unit to purchase??
Maria - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 118
All Time: 36,916
