Fujifilm Instax Mini Eight Camera Shell Replacement
  1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: step 1, image 1 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: step 1, image 2 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: step 1, image 3 of 3
    • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
    • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
  2. Fujifilm Instax Mini Eight Camera Shell Replacement: step 2, image 1 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 2, image 2 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 2, image 3 of 3
    • Press the tab down in order to unlatch the film compartment cover.
    • Remove the film from the compartment (if any is present)
    • Remove the compartment cover completely.
    • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
  3. Fujifilm Instax Mini Eight Camera Shell Replacement: step 3, image 1 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 3, image 2 of 3 Fujifilm Instax Mini Eight Camera Shell Replacement: step 3, image 3 of 3
    • Use the plastic opening tools and spudger to safely remove the front shell casing.
  4. Fujifilm Instax Mini Eight Camera Shell Replacement: step 4, image 1 of 2 Fujifilm Instax Mini Eight Camera Shell Replacement: step 4, image 2 of 2
    • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
    • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
    • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
13 other people completed this guide.
Bo W
1,025 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
26 Guides authored
18 Guide Comments
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - Reply
but where near the exit? i cannot find it
Emily Birkler -
It's at the top of the camera where you get picture.
xxx -
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - Reply
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - Reply
Past 24 Hours: 12
Past 7 Days: 75
Past 30 Days: 315
All Time: 69,309
