Introduction
In this guide you will need two tools: a Phillips #00 screwdriver and a soldering iron. Take caution when taking out the bulb especially if the capacitor is in tact, you may get shocked if you touch it.
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Once the shell is off, remove the one 6.5 mm screw that is attached to the flash bulb using a Phillips #00 screwdriver.
3 Comments
Hi, does anyone know how to find replacement bulb?
same question here!
Hi, I did bulb replacement on Mini 40 with the help of this guide. I found similar looking bulb on Aliexpress. I suggest you to look online for a replacement xenon tube lamp that is similar in look and length. I found lamp for Nikon models ******D40 D40X D60 D60X D3000 fitting and working fine with Instax Mini 40
