Fujifilm X100V Main board Replacement
  1. Fujifilm X100V Main board Replacement, Peel off leatherette: step 1, image 1 of 2 Fujifilm X100V Main board Replacement, Peel off leatherette: step 1, image 2 of 2
    • Peel off leatherette on the back left side, near the LCD and the viewfinder. It reveals two screws.
  2. Fujifilm X100V Main board Replacement, Unscrew the bottom panel: step 2, image 1 of 2 Fujifilm X100V Main board Replacement, Unscrew the bottom panel: step 2, image 2 of 2
    • Unscrew five screws. No need to touch the pair near the mounting hole.
  3. Fujifilm X100V Main board Replacement, Unscrew port panel cover: step 3, image 1 of 1
    • Unscrew two screws.
    • Carefully pry off the port cover panel together with the flap cover. Try not to damage the spring.
  4. Fujifilm X100V Main board Replacement, Unscrew two screws under the letherette: step 4, image 1 of 1
    • Unscrew these
  5. Fujifilm X100V Main board Replacement, Unscrew two screws under the LCD: step 5, image 1 of 1
    • Open the LCD panel
    • Unscrew two screws near the top
    • Note that they are of different length, the one near the viewfinder is longer.
  6. Fujifilm X100V Main board Replacement, Take off the back cover with the LCD: step 6, image 1 of 2 Fujifilm X100V Main board Replacement, Take off the back cover with the LCD: step 6, image 2 of 2
    • Carefully pull the cover out. It may be held by the two blocks of thermal paste (yellow markers).
    • Pull off the white ribbon cable. Before pulling out the orange one, unlock the bar on the connector. See red markers.
    • Use a thin tip spludger to unstick rubber foam near the viewfinder that may be holding the back cover.
  7. Fujifilm X100V Main board Replacement, Disconnect cables on the visible side: step 7, image 1 of 2 Fujifilm X100V Main board Replacement, Disconnect cables on the visible side: step 7, image 2 of 2
    • Peel off black (and one white) sticky patches that cover connectors.
    • Remember which patch goes to which spot.
    • Pull off the white ribbon cable (yellow marker)
    • Unlock and disconnect orange cables.
    • Unsolder the speaker.
  8. Fujifilm X100V Main board Replacement, Unscrew the motherboard: step 8, image 1 of 1
    • Unscrew four screws
    • Slightly bend the board to release it from the plastic hook (yellow marker)
  9. Fujifilm X100V Main board Replacement, Disconnect cables from the hidden side of the board: step 9, image 1 of 2 Fujifilm X100V Main board Replacement, Disconnect cables from the hidden side of the board: step 9, image 2 of 2
    • Disconnect two ribbon cables.
    • Unsolder four wires going to the battery.
  10. Fujifilm X100V Main board Replacement, Transfer sticky pads to the new board: step 10, image 1 of 1
    • Peel off the round foam pad and all patches and reattach them to the replacement motherboard.
    • Be careful with the patch with copper foil (not on the picture), it is fragile.
  11. Fujifilm X100V Main board Replacement, Solder battery wires: step 11, image 1 of 1
    • I am rather ashamed, but hey, it works!
    • My Hakko FX888D could not sufficiently heat the pads, I had to use a bigger soldering iron.
  12. Fujifilm X100V Main board Replacement, Connect downside cables: step 12, image 1 of 2 Fujifilm X100V Main board Replacement, Connect downside cables: step 12, image 2 of 2
    • Connect and lock the wider cable
    • Insert the narrow cable. It is rather fiddly, you need to push it from the side with a pinzette.
  13. Fujifilm X100V Main board Replacement, Connect upper side cables: step 13, image 1 of 1
    • Push the board in place and under the hook.
    • Connect and lock all the numerous upper side ribbon cables.
    • Solder the speaker
  14. Fujifilm X100V Main board Replacement, Screw the board in place: step 14, image 1 of 2 Fujifilm X100V Main board Replacement, Screw the board in place: step 14, image 2 of 2
    • Screw the board with four screws.
    • Put in place sticky patches.
  15. Fujifilm X100V Main board Replacement, Connect the back cover: step 15, image 1 of 1
    • Connect two ribbon cables.
    • Put in place two blocks of thermal paste
    • Put the back cover in place.
    • Carefully bend out the spring of the port panel cover and put the cover in place.
    • Screw six screws that hold the back cover.
    • Close and screw the bottom cover
Finish Line
crosser
278 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 109
All Time: 396
