Fujitsu LIFEBOOK P7010D Keyboard Replacement
  1. Fujitsu LIFEBOOK P7010D Keyboard Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down on a table.
  2. Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 2, image 1 of 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery near the side of the laptop.
    • Using your fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 3, image 1 of 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Keyboard Replacement, Keyboard: step 4, image 1 of 2 Fujitsu LIFEBOOK P7010D Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
  5. Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 5, image 1 of 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 5, image 2 of 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 5, image 3 of 3
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
  6. Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 6, image 1 of 2 Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
  7. Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 7, image 1 of 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 7, image 2 of 3 Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 7, image 3 of 3
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
  8. Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 8, image 1 of 2 Fujitsu LIFEBOOK P7010D Keyboard Replacement: step 8, image 2 of 2
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
Nicholas Ross
186 Reputation
7 Guides authored
Cal Poly, Team 10-31, Amido Winter 2012 Member of Cal Poly, Team 10-31, Amido Winter 2012
CPSU-AMIDO-W12S10G31
5 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 4,370
