Fujitsu LifeBook N3510 Keyboard Replacement
  1. Fujitsu LifeBook N3510 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Keyboard Replacement: step 2, image 1 of 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: step 3, image 1 of 3 Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: step 3, image 2 of 3 Fujitsu LifeBook N3510 Keyboard Replacement, Hinge Cover: step 3, image 3 of 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Keyboard Replacement: step 4, image 1 of 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Keyboard Replacement: step 5, image 1 of 3 Fujitsu LifeBook N3510 Keyboard Replacement: step 5, image 2 of 3 Fujitsu LifeBook N3510 Keyboard Replacement: step 5, image 3 of 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Keyboard Replacement: step 6, image 1 of 2 Fujitsu LifeBook N3510 Keyboard Replacement: step 6, image 2 of 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Keyboard Replacement: step 7, image 1 of 2 Fujitsu LifeBook N3510 Keyboard Replacement: step 7, image 2 of 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: step 8, image 1 of 3 Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: step 8, image 2 of 3 Fujitsu LifeBook N3510 Keyboard Replacement, Keyboard: step 8, image 3 of 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Keyboard Replacement: step 9, image 1 of 2 Fujitsu LifeBook N3510 Keyboard Replacement: step 9, image 2 of 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Keyboard Replacement: step 10, image 1 of 2 Fujitsu LifeBook N3510 Keyboard Replacement: step 10, image 2 of 2
    • After the ribbon has been detached, carefully remove the keyboard.
Neil Daniels
1,411 Reputation
11 Guides authored
Cal Poly, Team 5-18, Amido Winter 2011 Member of Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Members
23 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 6,223
