Fujitsu Lifebook E556 RAM Replacement
  1. Fujitsu Lifebook E556 RAM Replacement, Removing Battery: step 1, image 1 of 1
    • Remove battery:
    • 1. Pull down and hold that little tab.
    • 2. Move left that slider.
    • 3. Pull up to remove battery from laptop.
  2. Fujitsu Lifebook E556 RAM Replacement, Removing RAM Cover: step 2, image 1 of 1
    • To remove RAM cover, you need to:
    • 1. Remove screw holding that cover.
    • 2. Pull up the cover by notch visible right next to screw hole.
  3. Fujitsu Lifebook E556 RAM Replacement, Removing RAM Modules: step 3, image 1 of 1
    • To remove RAM modules, simlpy pull away tabs marked by white ovals.
    • RAM module should pop-up and it'll be possible to pull it out.
Michał Kurda
920 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 376
