Fujitsu Lifebook S6120 Fan Replacement
  1. Fujitsu Lifebook S6120 Fan Replacement, Battery: step 1, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, Battery: step 1, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, Battery: step 1, image 3 of 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: step 2, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement, Hinge Cover: step 2, image 2 of 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Fan Replacement: step 3, image 1 of 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Fan Replacement: step 4, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 4, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Fan Replacement: step 5, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 5, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 5, image 3 of 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Fan Replacement, Keyboard: step 6, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: step 6, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, Keyboard: step 6, image 3 of 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Fan Replacement: step 7, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 7, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: step 8, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: step 8, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, PCI Adapter: step 8, image 3 of 3
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Fan Replacement: step 9, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 9, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 9, image 3 of 3
    Buy
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Fan Replacement: step 10, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 10, image 2 of 2
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Fan Replacement, Motherboard: step 11, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement, Motherboard: step 11, image 2 of 2
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  12. Fujitsu Lifebook S6120 Fan Replacement: step 12, image 1 of 1
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  13. Fujitsu Lifebook S6120 Fan Replacement: step 13, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 13, image 2 of 2
    Buy
    • Remove the ribbon from the motherboard with a pair of tweezers.
  14. Fujitsu Lifebook S6120 Fan Replacement: step 14, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 14, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 14, image 3 of 3
    • Use a 5mm nut driver to unscrew the nuts.
  15. Fujitsu Lifebook S6120 Fan Replacement: step 15, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 15, image 2 of 2
    • Pull the ribbon tab up and off the motherboard.
  16. Fujitsu Lifebook S6120 Fan Replacement: step 16, image 1 of 1
    • Remove the metal plate covering the motherboard.
  17. Fujitsu Lifebook S6120 Fan Replacement: step 17, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 17, image 2 of 2
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  18. Fujitsu Lifebook S6120 Fan Replacement: step 18, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 18, image 2 of 2
    • Pinch your fingers around the base of the connector and pull it out.
  19. Fujitsu Lifebook S6120 Fan Replacement: step 19, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 19, image 2 of 2
    • Lift the motherboard off the plastic base.
  20. Fujitsu Lifebook S6120 Fan Replacement, Fan: step 20, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement, Fan: step 20, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement, Fan: step 20, image 3 of 3
    • Using a Philips head size #0 remove the 3mm screw on the back of the motherboard.
  21. Fujitsu Lifebook S6120 Fan Replacement: step 21, image 1 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 21, image 2 of 3 Fujitsu Lifebook S6120 Fan Replacement: step 21, image 3 of 3
    Buy
    • Using tweezers detach the cable from the motherboard.
  22. Fujitsu Lifebook S6120 Fan Replacement: step 22, image 1 of 2 Fujitsu Lifebook S6120 Fan Replacement: step 22, image 2 of 2
    • The fan can now be removed from the motherboard.
Jessi Gallant
899 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 657
