Fujitsu Lifebook S6120 Hinge Cover Replacement
  1. Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: step 1, image 1 of 3 Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: step 1, image 2 of 3 Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: step 1, image 3 of 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Hinge Cover Replacement, Hinge Cover: step 2, image 1 of 2 Fujitsu Lifebook S6120 Hinge Cover Replacement, Hinge Cover: step 2, image 2 of 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Hinge Cover Replacement: step 3, image 1 of 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Hinge Cover Replacement: step 4, image 1 of 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: step 4, image 2 of 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Hinge Cover Replacement: step 5, image 1 of 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: step 5, image 2 of 3 Fujitsu Lifebook S6120 Hinge Cover Replacement: step 5, image 3 of 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
Jaimie Nakamura
229 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 375
