Fujitsu Lifebook S6120 RAM Replacement
  1. Fujitsu Lifebook S6120 RAM Replacement, Battery: step 1, image 1 of 3 Fujitsu Lifebook S6120 RAM Replacement, Battery: step 1, image 2 of 3 Fujitsu Lifebook S6120 RAM Replacement, Battery: step 1, image 3 of 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 RAM Replacement, RAM: step 2, image 1 of 2 Fujitsu Lifebook S6120 RAM Replacement, RAM: step 2, image 2 of 2
    • Use a Philips head #0 to remove the 4mm screws to the RAM cover.
  3. Fujitsu Lifebook S6120 RAM Replacement: step 3, image 1 of 3 Fujitsu Lifebook S6120 RAM Replacement: step 3, image 2 of 3 Fujitsu Lifebook S6120 RAM Replacement: step 3, image 3 of 3
    • Use the plastic opening tool to lift the RAM cover.
    • Use your hands to slide the cover off.
  4. Fujitsu Lifebook S6120 RAM Replacement: step 4, image 1 of 3 Fujitsu Lifebook S6120 RAM Replacement: step 4, image 2 of 3 Fujitsu Lifebook S6120 RAM Replacement: step 4, image 3 of 3
    • Remove RAM module by pushing security clips outward.
    • The RAM module should pop out.
    • Carefully pull RAM module out of the computer.
Jessi Gallant
899 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 414
