Fujitsu Lifebook S6120 Screen Replacement
  1. Fujitsu Lifebook S6120 Screen Replacement, Battery: step 1, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement, Battery: step 1, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement, Battery: step 1, image 3 of 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: step 2, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: step 2, image 2 of 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Screen Replacement: step 3, image 1 of 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Screen Replacement: step 4, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 4, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Screen Replacement: step 5, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 5, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 5, image 3 of 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: step 6, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: step 6, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement, Keyboard: step 6, image 3 of 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Screen Replacement: step 7, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 7, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: step 8, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: step 8, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: step 8, image 3 of 3
    • Push the secure clips outward.
    • The Adapter should pop up.
  9. Fujitsu Lifebook S6120 Screen Replacement: step 9, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 9, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 9, image 3 of 3
    Buy
    • Use tweezers to remove the wires from the Adapter.
  10. Fujitsu Lifebook S6120 Screen Replacement: step 10, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement: step 10, image 2 of 2
    • Take out the Adapter and carefully pull the wires out from the metal casing.
  11. Fujitsu Lifebook S6120 Screen Replacement, Screen: step 11, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement, Screen: step 11, image 2 of 2
    • Remove the 4mm screws from the laptop with a Philips head #0
    • Remove the 4.5mm screws on the back of the laptop with a Philips #0
  12. Fujitsu Lifebook S6120 Screen Replacement: step 12, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 12, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 12, image 3 of 3
    • Use a plastic opening tool to lift up both sides of the white tab.
  13. Fujitsu Lifebook S6120 Screen Replacement: step 13, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement: step 13, image 2 of 2
    Buy
    • Use tweezers to grab onto the lever to remove the chip from the motherboard.
  14. Fujitsu Lifebook S6120 Screen Replacement: step 14, image 1 of 1
    • Lift the screen up vertically
  15. Fujitsu Lifebook S6120 Screen Replacement: step 15, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 15, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 15, image 3 of 3
    • Remove rubber tabs with hands
    • Use a Philips head #0 to remove the 3mm screws
  16. Fujitsu Lifebook S6120 Screen Replacement: step 16, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement: step 16, image 2 of 2
    • Use the metal spudger to pry up the edge of the plastic casing up.
    • Remove the plastic frame from the screen.
  17. Fujitsu Lifebook S6120 Screen Replacement: step 17, image 1 of 1
    • Remove the 3mm screws with a Philips head #00
  18. Fujitsu Lifebook S6120 Screen Replacement: step 18, image 1 of 1
    • Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
  19. Fujitsu Lifebook S6120 Screen Replacement: step 19, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement: step 19, image 2 of 2
    • Lift the screen from the frame
  20. Fujitsu Lifebook S6120 Screen Replacement: step 20, image 1 of 2 Fujitsu Lifebook S6120 Screen Replacement: step 20, image 2 of 2
    • Remove the ribbon from the back of the screen
  21. Fujitsu Lifebook S6120 Screen Replacement: step 21, image 1 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 21, image 2 of 3 Fujitsu Lifebook S6120 Screen Replacement: step 21, image 3 of 3
    • Use a pair of tweezers remove the white connector
Jessi Gallant
899 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 12
All Time: 980
