Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement
  1. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Inner Back Shield: step 4, image 1 of 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 5, image 1 of 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 6, image 1 of 1
  7. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 7, image 1 of 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Battery: step 8, image 1 of 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 9, image 1 of 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 10, image 1 of 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 11, image 1 of 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Headphone Jack: step 12, image 1 of 1
    • Remove the two 0.2 mm screws with a PH00 Screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 13, image 1 of 1
    • Remove the two 0.2 mm screws with a PH00 screwdriver
  14. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 14, image 1 of 1
    • Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
  15. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 15, image 1 of 2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 15, image 2 of 2
    • Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
  16. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 16, image 1 of 2 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: step 16, image 2 of 2
    • When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
Briana Cockerham
130 Reputation
1 Guide authored
IUPUI, Team S1-G1, Henning Spring 2019 Member of IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 453
