Fujitsu Lifebook T1010 RAM Replacement
  1. Fujitsu Lifebook T1010 RAM  Replacement, RAM: step 1, image 1 of 1
    • Remove the two Phillips #0 screws from the cover.
  2. Fujitsu Lifebook T1010 RAM  Replacement: step 2, image 1 of 1
    • Remove the cover.
  3. Fujitsu Lifebook T1010 RAM  Replacement: step 3, image 1 of 1
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
Chitara Smith
575 Reputation
3 Guides authored
Gateway, Team S1-G3, Johnson Spring 2018 Member of Gateway, Team S1-G3, Johnson Spring 2018
GCC-JOHNSON-S18S1G3
2 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 415
