Function Key Motherboard
  1. Function Key Motherboard, Front and Back Covers: step 1, image 1 of 3 Function Key Motherboard, Front and Back Covers: step 1, image 2 of 3 Function Key Motherboard, Front and Back Covers: step 1, image 3 of 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Function Key Motherboard: step 2, image 1 of 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Function Key Motherboard: step 3, image 1 of 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Function Key Motherboard: step 4, image 1 of 2 Function Key Motherboard: step 4, image 2 of 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Function Key Motherboard: step 5, image 1 of 1
    • The camera should look like this once the front cover is removed.
  6. Function Key Motherboard: step 6, image 1 of 3 Function Key Motherboard: step 6, image 2 of 3 Function Key Motherboard: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Function Key Motherboard: step 7, image 1 of 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Function Key Motherboard, Function Key Motherboard: step 8, image 1 of 3 Function Key Motherboard, Function Key Motherboard: step 8, image 2 of 3 Function Key Motherboard, Function Key Motherboard: step 8, image 3 of 3
    • Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
    • Caution: Do not tug on the LCD screen because this could tear the ribbon connecting the LCD screen to the body of the camera.
    • Loosen the black ribbon clamp using an iPod opening tool
    • Release the LCD screen by removing the ribbon from the body of the camera.
  9. Function Key Motherboard: step 9, image 1 of 2 Function Key Motherboard: step 9, image 2 of 2
    • Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
    • Caution: Do not tug on the motherboard because this will tear the ribbon connecting the motherboard to the body of the camera.
  10. Function Key Motherboard: step 10, image 1 of 3 Function Key Motherboard: step 10, image 2 of 3 Function Key Motherboard: step 10, image 3 of 3
    Buy
    • Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
    • Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
    • The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
Shaelyn Thomas
392 Reputation
4 Guides authored
Cal Poly, Team 8-6, Regan Spring 2011 Member of Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 3,421
