Furnace Humidifier Evaporator Pad Replacement
  1. Furnace Humidifier Evaporator Pad Replacement, Furnace Humidifier Evaporator Pad: step 1, image 1 of 1
    • Turn off the humidifier. (Set the humidistat to 0% humidity)
  2. Furnace Humidifier Evaporator Pad Replacement: step 2, image 1 of 2 Furnace Humidifier Evaporator Pad Replacement: step 2, image 2 of 2
    • Remove the nuts and clips holding the top cover of the cabinet assembly to the bottom cabinet housing.
  3. Furnace Humidifier Evaporator Pad Replacement: step 3, image 1 of 1
    • Remove the side clips or fasteners.
  4. Furnace Humidifier Evaporator Pad Replacement: step 4, image 1 of 1
    • Use an adjustable wrench to loosen the nut which holds the water distributor tube and swing the tube out of its secured place.
  5. Furnace Humidifier Evaporator Pad Replacement: step 5, image 1 of 1
    • Remove the top of the bottom cabinet housing and take out the evaporator pad.
  6. Furnace Humidifier Evaporator Pad Replacement: step 6, image 1 of 2 Furnace Humidifier Evaporator Pad Replacement: step 6, image 2 of 2
    • Place the new evaporator pad inside the clean bottom cabinet.
    • The sides should guide it into the correct position.
  7. Furnace Humidifier Evaporator Pad Replacement: step 7, image 1 of 1
    • Replace the clips, nuts, and bolts removed in steps 2 through 4.
  8. Furnace Humidifier Evaporator Pad Replacement: step 8, image 1 of 1
    • Turn on the humidifier.
Enjoy your warm air! Your repair is complete!
Zia Ahmed
190 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 394
