GATEWAY ML6720 Disc Drive Replacement
  1. GATEWAY ML6720 Disc Drive Replacement, Disc Drive: step 1, image 1 of 1
    • Remove the six screws with the Phillips #0 Screwdriver that secures the middle large piece of the back panel.
  2. GATEWAY ML6720 Disc Drive Replacement: step 2, image 1 of 2 GATEWAY ML6720 Disc Drive Replacement: step 2, image 2 of 2
    • Check to see if your laptop requires a screw(s) to be removed for the disc drive. Remove the screw (s) holding the disc drive down.
  3. GATEWAY ML6720 Disc Drive Replacement: step 3, image 1 of 2 GATEWAY ML6720 Disc Drive Replacement: step 3, image 2 of 2
    • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Semirah Dolan
113 Reputation
1 Guide authored
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 308
