GATEWAY ML6720 Hard Drive Replacement
  1. GATEWAY ML6720 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip the laptop on to its backside.
  2. GATEWAY ML6720 Hard Drive Replacement: step 2, image 1 of 1
    • Locate the hard drive at the bottom left corner of the laptop's backside.
  3. GATEWAY ML6720 Hard Drive Replacement: step 3, image 1 of 2 GATEWAY ML6720 Hard Drive Replacement: step 3, image 2 of 2
    • Insert the correct screwdriver mentioned in this guide.
    • Fully loosen and remove each of the two screws located at the top left and bottom left corners of the hard drive's cover plate.
  4. GATEWAY ML6720 Hard Drive Replacement: step 4, image 1 of 1
    • Slide the hard drive's cover plate out to the left and take it off.
  5. GATEWAY ML6720 Hard Drive Replacement: step 5, image 1 of 1
    • Pop the hard drive out of the compartment.
Nathan Da Silva
416 Reputation
4 Guides authored
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 486
