GD Midea FT30-3D Fan Blades Replacement
  1. GD Midea FT30-3D Fan Blades Replacement, Fan Blades: step 1, image 1 of 2 GD Midea FT30-3D Fan Blades Replacement, Fan Blades: step 1, image 2 of 2
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. GD Midea FT30-3D Fan Blades Replacement: step 2, image 1 of 1
    • Pull the front fan guard off.
  3. GD Midea FT30-3D Fan Blades Replacement: step 3, image 1 of 2 GD Midea FT30-3D Fan Blades Replacement: step 3, image 2 of 2
    • Remove the spinner from the center of the fan blade.
  4. GD Midea FT30-3D Fan Blades Replacement: step 4, image 1 of 1
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
6 other people completed this guide.
Alan Su
810 Reputation
6 Guides authored
Cal Poly, Team 24-28, Regan Fall 2012 Member of Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Members
14 Guides authored
One Comment
Where do you buy the fan blades?
charlie - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 3,340
