Introduction
In this guide, the user will learn how to properly disconnect the hoses to the ventilator in order to do a visual inspection for debris. Steps one through three can be found in the GE Carescape support video titled Gas Inlet, O2, and Air Filter and explain how to properly disconnect the hoses from the machine. Steps four and five are from the GE Carescape Manual on page 5-4 and instruct the user on how to clean the filter if debris is found.
For the full video, please visit https://services.gehealthcare.com/gehcst...
After 20 seconds:
Close both shut-off valves. Pulse the Air and O2 flow valves 5 times for 5 seconds.
Set the Air DAC counts to zero (closed).
Set the O2 DAC counts to zero (closed).
Note: Closing the shut-off valves before setting the flow DAC counts to zero, bleeds pressure from the system.
