GE Carescape R860 Alarm Light (PWA) Board Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. GE Carescape R860 Alarm Light (PWA) Board Replacement, GE Carescape R860 Display Unit Disassembly: step 1, image 1 of 1
    • Using an opening tool, gently pry the alarm light lens (boxed) from the display unit.
  2. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 2, image 1 of 1
    • Loosen the seven screws that hold the rear housing using a Phillips #0 screwdriver.
    • Remove the rear housing.
  3. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 3, image 1 of 1
    • Cut the cable tie holding the two cables at the lower right side using scissors.
  4. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 4, image 1 of 1
    • Disconnect the touch controller cable.
  5. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 5, image 1 of 1
    • Disconnect the Keypad harness at the Carrier Board.
  6. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 6, image 1 of 1
    • Disconnect the encoder harness from the Carrier Board.
  7. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 7, image 1 of 1
    • Disconnect the speaker harness from the Carrier Board and set the speakers aside.
  8. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 8, image 1 of 1
    • Disconnect the alarm light harness from the Carrier Board.
  9. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 9, image 1 of 1
    • Loosen (do not remove) the five screws at the top edge of the shield just enough to raise it and slide the shield away with a Phillips #0 screwdriver.
  10. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 10, image 1 of 1
    • Loosen the four screws along each side of the shield with a Phillips #0 screwdriver.
  11. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 11, image 1 of 1
    • Remove the four screws at the bottom edge of the shield with a Phillips #0 screwdriver.
  12. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 12, image 1 of 1
    • Slide the shield down to disengage the touch controller harness connector.
  13. GE Carescape R860 Alarm Light (PWA) Board Replacement, Alarm Light (PWA) Board: step 13, image 1 of 1
    • Pull the PWA board from the slot.
    • Replace the PWA board.
  14. GE Carescape R860 Alarm Light (PWA) Board Replacement: step 14, image 1 of 1
    • Reconnect the alarm light harness.
Andre Fisher
357 Reputation
2 Guides authored
Cal Poly, Team S7-G9, Paton Spring 2020 Member of Cal Poly, Team S7-G9, Paton Spring 2020
CPSU-PATON-S20S7G9
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 332
