GE Carescape R860 Display Unit Disassembly
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. GE Carescape R860 Display Unit Disassembly, GE Carescape R860 Display Unit Disassembly: step 1, image 1 of 1
    • Using an opening tool, gently pry the alarm light lens (boxed) from the display unit.
  2. GE Carescape R860 Display Unit Disassembly: step 2, image 1 of 1
    • Loosen the seven screws that hold the rear housing using a Phillips #0 screwdriver.
    • Remove the rear housing.
  3. GE Carescape R860 Display Unit Disassembly: step 3, image 1 of 1
    • Cut the cable tie holding the two cables at the lower right side using scissors.
  4. GE Carescape R860 Display Unit Disassembly: step 4, image 1 of 1
    • Disconnect the touch controller cable.
  5. GE Carescape R860 Display Unit Disassembly: step 5, image 1 of 1
    • Disconnect the Keypad harness at the Carrier Board.
  6. GE Carescape R860 Display Unit Disassembly: step 6, image 1 of 1
    • Disconnect the encoder harness from the Carrier Board.
  7. GE Carescape R860 Display Unit Disassembly: step 7, image 1 of 1
    • Disconnect the speaker harness from the Carrier Board and set the speakers aside.
  8. GE Carescape R860 Display Unit Disassembly: step 8, image 1 of 1
    • Disconnect the alarm light harness from the Carrier Board.
  9. GE Carescape R860 Display Unit Disassembly: step 9, image 1 of 1
    • Loosen (do not remove) the five screws at the top edge of the shield just enough to raise it and slide the shield away with a Phillips #0 screwdriver.
  10. GE Carescape R860 Display Unit Disassembly: step 10, image 1 of 1
    • Loosen the four screws along each side of the shield with a Phillips #0 screwdriver.
  11. GE Carescape R860 Display Unit Disassembly: step 11, image 1 of 1
    • Remove the four screws at the bottom edge of the shield with a Phillips #0 screwdriver.
  12. GE Carescape R860 Display Unit Disassembly: step 12, image 1 of 1
    • Slide the shield down to disengage the touch controller harness connector.
Andre Fisher
357 Reputation
2 Guides authored
Cal Poly, Team S7-G9, Paton Spring 2020 Member of Cal Poly, Team S7-G9, Paton Spring 2020
CPSU-PATON-S20S7G9
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 366
