GE Carescape R860 Touch Bezel Assembly Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. GE Carescape R860 Touch Bezel Assembly Replacement, GE Carescape R860 Display Unit Disassembly: step 1, image 1 of 1
    • Using an opening tool, gently pry the alarm light lens (boxed) from the display unit.
  2. GE Carescape R860 Touch Bezel Assembly Replacement: step 2, image 1 of 1
    • Loosen the seven screws that hold the rear housing using a Phillips #0 screwdriver.
    • Remove the rear housing.
  3. GE Carescape R860 Touch Bezel Assembly Replacement: step 3, image 1 of 1
    • Cut the cable tie holding the two cables at the lower right side using scissors.
  4. GE Carescape R860 Touch Bezel Assembly Replacement: step 4, image 1 of 1
    • Disconnect the touch controller cable.
  5. GE Carescape R860 Touch Bezel Assembly Replacement: step 5, image 1 of 1
    • Disconnect the Keypad harness at the Carrier Board.
  6. GE Carescape R860 Touch Bezel Assembly Replacement: step 6, image 1 of 1
    • Disconnect the encoder harness from the Carrier Board.
  7. GE Carescape R860 Touch Bezel Assembly Replacement: step 7, image 1 of 1
    • Disconnect the speaker harness from the Carrier Board and set the speakers aside.
  8. GE Carescape R860 Touch Bezel Assembly Replacement: step 8, image 1 of 1
    • Disconnect the alarm light harness from the Carrier Board.
  9. GE Carescape R860 Touch Bezel Assembly Replacement: step 9, image 1 of 1
    • Loosen (do not remove) the five screws at the top edge of the shield just enough to raise it and slide the shield away with a Phillips #0 screwdriver.
  10. GE Carescape R860 Touch Bezel Assembly Replacement: step 10, image 1 of 1
    • Loosen the four screws along each side of the shield with a Phillips #0 screwdriver.
  11. GE Carescape R860 Touch Bezel Assembly Replacement: step 11, image 1 of 1
    • Remove the four screws at the bottom edge of the shield with a Phillips #0 screwdriver.
  12. GE Carescape R860 Touch Bezel Assembly Replacement: step 12, image 1 of 1
    • Slide the shield down to disengage the touch controller harness connector.
  13. GE Carescape R860 Touch Bezel Assembly Replacement, Touch Bezel Assembly: step 13, image 1 of 1
    • Remove rear housing and shield (refer to “Display Unit Disassembly”).
  14. GE Carescape R860 Touch Bezel Assembly Replacement: step 14, image 1 of 1
    • Disconnect the Blower fan cable (A); remove the p-clip (B) holding the harness to the Carrier board.
  15. GE Carescape R860 Touch Bezel Assembly Replacement: step 15, image 1 of 1
    • Disconnect the Carrier board to LCD LVDS harness (22) - two connectors.
  16. GE Carescape R860 Touch Bezel Assembly Replacement: step 16, image 1 of 1
    • Remove five LCD shield mounting screws (circled). Do not loosen any screws that are dabbed with sealing compound.
  17. GE Carescape R860 Touch Bezel Assembly Replacement: step 17, image 1 of 2 GE Carescape R860 Touch Bezel Assembly Replacement: step 17, image 2 of 2
    • Remove the LCD shield and Carrier board assembly from the LCD Touch Bezel assembly.
  18. GE Carescape R860 Touch Bezel Assembly Replacement: step 18, image 1 of 1
    • Transfer the Carrier Board to Keypad harness (23) and the Encoder assembly (15) to the new LCD Touch Bezel assembly.
Seth Deming
133 Reputation
1 Guide authored
Cal Poly, Team S7-G9, Paton Spring 2020 Member of Cal Poly, Team S7-G9, Paton Spring 2020
CPSU-PATON-S20S7G9
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 192
