GE Refrigerator Main Control Board Replacement
  1. GE Refrigerator Main Control Board Replacement, Unplug your refrigerator: step 1, image 1 of 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Refrigerator Main Control Board Replacement, Remove the main control board cover: step 2, image 1 of 3 GE Refrigerator Main Control Board Replacement, Remove the main control board cover: step 2, image 2 of 3 GE Refrigerator Main Control Board Replacement, Remove the main control board cover: step 2, image 3 of 3
    • Use a 1/4" nut driver to remove the screws securing the main control board cover.
    • Remove the main control board cover.
  3. GE Refrigerator Main Control Board Replacement, Disconnect the main control board: step 3, image 1 of 3 GE Refrigerator Main Control Board Replacement, Disconnect the main control board: step 3, image 2 of 3 GE Refrigerator Main Control Board Replacement, Disconnect the main control board: step 3, image 3 of 3
    • Note or take a photo of the position of all of the connectors
    • With your fingers, grasp each connector, squeeze any locking tabs, and pull all the connectors off the board.
  4. GE Refrigerator Main Control Board Replacement, Remove the main control board: step 4, image 1 of 3 GE Refrigerator Main Control Board Replacement, Remove the main control board: step 4, image 2 of 3 GE Refrigerator Main Control Board Replacement, Remove the main control board: step 4, image 3 of 3
    • Using long nose pliers, squeeze the locking tabs on the mounting studs. While you do this, with your other hand pull the board gently outward so that the board won't slip back over a stud that has been released.
    • Lift the area of the board closest to the stud to free it from the mounting studs
    • Repeat this process of each mounting stud. until the board is free of each stud. Remove the board.
    • Try to work from one corner of the board down one side, then across. That will make it easier to maintain the gentle outward pressure and prevent the board from slipping back over the studs.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
38,781 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,991 Guides authored
1 Guide Comment
Control board 245D1888G002 R57 light blink all the time
Freddie Mckinney - Reply
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 66
All Time: 879
