GM Key Fob Plastic Housing Replacement
  1. GM Key Fob  Plastic Housing Replacement, Key Fob Plastic Housing: step 1, image 1 of 1
    • Pry apart the key ring to remove it from the old housing.
  2. GM Key Fob  Plastic Housing Replacement: step 2, image 1 of 3 GM Key Fob  Plastic Housing Replacement: step 2, image 2 of 3 GM Key Fob  Plastic Housing Replacement: step 2, image 3 of 3
    • Once you have removed the key ring, use it to open the housing by wedging it into the groove, as pictured.
  3. GM Key Fob  Plastic Housing Replacement: step 3, image 1 of 2 GM Key Fob  Plastic Housing Replacement: step 3, image 2 of 2
    • Remove the electrical board and rubber key pad from the old housing.
  4. GM Key Fob  Plastic Housing Replacement: step 4, image 1 of 2 GM Key Fob  Plastic Housing Replacement: step 4, image 2 of 2
    • Remove the electrical board from the rubber key pad.
  5. GM Key Fob  Plastic Housing Replacement: step 5, image 1 of 2 GM Key Fob  Plastic Housing Replacement: step 5, image 2 of 2
    • If necessary, remove the battery from the electrical board and replace it.
  6. GM Key Fob  Plastic Housing Replacement: step 6, image 1 of 1
    • After Opening the new Key Fob package, select the correct housing as more than one model is included.
To reassemble your device, simply follow these disassembly instructions in reverse order.
2 other people completed this guide.
Megan Hayden
151 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 44
All Time: 3,224
