Galaxy J3 Prime LCD Screen Replacement
Video Overview
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
9 other people completed this guide.
Brian Brown
393 Reputation
1 Guide authored
3 Guide Comments
great guide, this really helped
anonymous 591 - Reply
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - Reply
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 29
All Time: 7,278
