Galaxy S20 SIM/MicroSD Card Tray Replacement
  1. Galaxy S20 SIM/MicroSD Card Tray Replacement, Eject the SIM tray: step 1, image 1 of 2 Galaxy S20 SIM/MicroSD Card Tray Replacement, Eject the SIM tray: step 1, image 2 of 2
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
  2. Galaxy S20 SIM/MicroSD Card Tray Replacement, Remove the SIM tray: step 2, image 1 of 2 Galaxy S20 SIM/MicroSD Card Tray Replacement, Remove the SIM tray: step 2, image 2 of 2
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
After you've completed the repair, follow this guide to test your repair.
Tarun Thiruma
36,244 Reputation
134 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 103
All Time: 2,533
