Game Boy Color Back Housing Replacement
  1. Game Boy Color Back Housing Replacement, Battery: step 1, image 1 of 2 Game Boy Color Back Housing Replacement, Battery: step 1, image 2 of 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Back Housing Replacement: step 2, image 1 of 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Back Housing Replacement, Back Housing: step 3, image 1 of 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Back Housing Replacement: step 4, image 1 of 2 Game Boy Color Back Housing Replacement: step 4, image 2 of 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
20 other people completed this guide.
Angela Yoeurng
1,950 Reputation
2 Guides authored
Cal Poly, Team 19-47, Regan Winter 2013 Member of Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Members
61 Guides authored
2 Guide Comments
Can’t seem to figure out how to remove the battery prongs off the back housing :(
Eddy G - Reply
If you didn't get it figured out, there is a small metal leg visible from the inside of the housing on the side closest to the edge of the housing. You can press the leg down with a pair of tweezers while pressing the battery prong plate down gently and it should pop free and allow you to push the prong out.
Wesley -
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 110
All Time: 10,650
