Game Boy Color Buttons Replacement
  1. Game Boy Color Buttons Replacement, Battery: step 1, image 1 of 2 Game Boy Color Buttons Replacement, Battery: step 1, image 2 of 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Buttons Replacement: step 2, image 1 of 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Buttons Replacement, Back Housing: step 3, image 1 of 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Buttons Replacement: step 4, image 1 of 2 Game Boy Color Buttons Replacement: step 4, image 2 of 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Buttons Replacement, LCD Ribbon Cable: step 5, image 1 of 3 Game Boy Color Buttons Replacement, LCD Ribbon Cable: step 5, image 2 of 3 Game Boy Color Buttons Replacement, LCD Ribbon Cable: step 5, image 3 of 3
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Buttons Replacement: step 6, image 1 of 2 Game Boy Color Buttons Replacement: step 6, image 2 of 2
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Buttons Replacement, Motherboard: step 7, image 1 of 2 Game Boy Color Buttons Replacement, Motherboard: step 7, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Buttons Replacement: step 8, image 1 of 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Buttons Replacement, Buttons: step 9, image 1 of 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Buttons Replacement: step 10, image 1 of 1
    • Remove the original buttons from the housing.
26 other people completed this guide.
Nick Katsantones
1,078 Reputation
4 Guides authored
Cal Poly, Team 19-47, Regan Winter 2013 Member of Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Members
61 Guides authored
3 Guide Comments
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Reply
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Reply
I found either Y0 or Y1 works. The important thing is it's a small tri-wing.
Michael Schwern -
Past 24 Hours: 16
Past 7 Days: 48
Past 30 Days: 243
All Time: 33,049
