Game Boy Color Power LED Replacement
  1. Game Boy Color Power LED Replacement, Battery: step 1, image 1 of 2 Game Boy Color Power LED Replacement, Battery: step 1, image 2 of 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Power LED Replacement: step 2, image 1 of 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Power LED Replacement, Back Housing: step 3, image 1 of 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Power LED Replacement: step 4, image 1 of 2 Game Boy Color Power LED Replacement: step 4, image 2 of 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Power LED Replacement, Motherboard: step 5, image 1 of 2 Game Boy Color Power LED Replacement, Motherboard: step 5, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  6. Game Boy Color Power LED Replacement: step 6, image 1 of 1
    • Gently lift the motherboard from the front housing.
  7. Game Boy Color Power LED Replacement, Power LED: step 7, image 1 of 2 Game Boy Color Power LED Replacement, Power LED: step 7, image 2 of 2
  8. Game Boy Color Power LED Replacement: step 8, image 1 of 1
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
  9. Game Boy Color Power LED Replacement: step 9, image 1 of 1
    • Solder the leads of the new LED to the circuit board.
  10. Game Boy Color Power LED Replacement: step 10, image 1 of 1
    • Cut the excess ends of the LED legs using the wire cutters.
8 other people completed this guide.
Alex Wu
1,664 Reputation
2 Guides authored
Cal Poly, Team 19-47, Regan Winter 2013 Member of Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Members
61 Guides authored
6 Guide Comments
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - Reply
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith -
and what kind of LED are you using to replace?
Soul Divide - Reply
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - Reply
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - Reply
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 106
All Time: 20,285
