Game Boy Pocket Power Button Replacement
  1. Game Boy Pocket Power Button Replacement, Remove the external screws: step 1, image 1 of 3 Game Boy Pocket Power Button Replacement, Remove the external screws: step 1, image 2 of 3 Game Boy Pocket Power Button Replacement, Remove the external screws: step 1, image 3 of 3
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Power Button Replacement, Open the device: step 2, image 1 of 3 Game Boy Pocket Power Button Replacement, Open the device: step 2, image 2 of 3 Game Boy Pocket Power Button Replacement, Open the device: step 2, image 3 of 3
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Power Button Replacement, Remove the power button: step 3, image 1 of 3 Game Boy Pocket Power Button Replacement, Remove the power button: step 3, image 2 of 3 Game Boy Pocket Power Button Replacement, Remove the power button: step 3, image 3 of 3
    • Use your fingers to remove the grey power button to the right of the ribbon cable.
Adriana Rahrig
1,637 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2014 Member of USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Members
19 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 20
All Time: 4,768
