GameSir X2 Type-C Left Trigger Replacement
  1. GameSir X2 Type-C Left Trigger Replacement, Back Cover: step 1, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement, Back Cover: step 1, image 2 of 2
    • Turn the device so the back faces you.
  2. GameSir X2 Type-C Left Trigger Replacement: step 2, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement: step 2, image 2 of 2
    • Remove the eight 6 mm T6 Torx screws.
  3. GameSir X2 Type-C Left Trigger Replacement: step 3, image 1 of 1
    • Use a straight edge to remove the rubber pad on the front of the device.
  4. GameSir X2 Type-C Left Trigger Replacement: step 4, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement: step 4, image 2 of 2
    • Remove the four 4.5 mm screws with a Phillips #000 screwdriver.
  5. GameSir X2 Type-C Left Trigger Replacement: step 5, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement: step 5, image 2 of 2
    • Use a straight edge to pry open the controller, following the seam on the controller.
    • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
  6. GameSir X2 Type-C Left Trigger Replacement, Left Trigger: step 6, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement, Left Trigger: step 6, image 2 of 2
    • Remove the two 6mm screws that secure the trigger assembly with a Phillips #000 screwdriver.
  7. GameSir X2 Type-C Left Trigger Replacement: step 7, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement: step 7, image 2 of 2
    • Remove the joystick cover.
  8. GameSir X2 Type-C Left Trigger Replacement: step 8, image 1 of 2 GameSir X2 Type-C Left Trigger Replacement: step 8, image 2 of 2
    • Lift the trigger assembly away from the device.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 801
